hey guyz i have an r32 gtst nd have recently discovered that my fuel tank nd pump are covered in rust, ive called almost every wreckers i can think of nd nobody has a gtst fuel tank, nissan quoted me $1400 for a new 1, which is way outta my budget. i have been told r32 gtr tanks fit but some degree of work is involved in installing into gtst. also heard that an sr20 tank would fit, is dis tru? if so which model. which workshop in perth would be most helpful? ne1 whose had this problem b4 plz tell me what u did.
cheers
muchly appreciated :D
https://www.sau.com.au/forums/topic/274130-who-can-replace-my-fuel-tank/
NatRad? where bouts they located? how do i check to see whether their mite be rust in a fuel tank that isnt visible? is there sum kind of chemical i can chuck in that can eat up the rust but wont contaminate the tank wen i put fuel in it later on?
I had issues with a couple of tanks and I've bought some gear by a mob called KBS Coatings. Basically it's a multi-stage process that cleans the tank out, then coats the inside with a sealer that stops the rust issues. Excellent stuff and $100.00 coats a 100 litre tank.
I still had the link for the product - KBS Coatings.
And these are the WA distributors - Distributor List.
I've used it on a couple of old project cars and an ex race 80's bike.
thanks mate, will i need to remove my tank to do this? how many litres is a R32 gtst fuel tank?
Yes, you remove the tank and fill it with the compound. Then seal the pump access hole and rotate the tank so the compound covers the entire surface.
The Gts-t is 60 litres from memory.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
