are you sure its a v-spec II because it is missing its carbon bonnet and rear carbon diffuser also the rear v-spec II sticker looks suss its not sitting in the right spot its too far to the left on the rear bumber, did you run the vin number through the nissan fast software?
While that may send off warning signals there are other factors that may have lead to the sticker having to be re-added to the car. resprays, accident damage or such. Its also possible that the CF bonnet may have been switched out...there are extra reasons for everything =b
As long as hes happy with it, should be all that really matters.
Cant be any worse than most of the GTS-ts in melbourne having GTR badges fitted to their boots.
Half of which are probably stolen from real GTRs...damn badge thieves.
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4653954
Its true, my bonnet is sold cos i wanted the ztune one so alot of people will have the same thoughts and yeah the rear bar was probably resprayed due to a crappy carpark driver (my front bar has been sprayed already and needs another one again; damn careless carparks grrrrr.)
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4654000
Thanks for the backup =D
But yeah there are any number of reasons it could be like that.
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4654161
yes thats pathetic
theres a black R34 GT-T with a GT-R badge at the boot
the whole car looks nothing like a GT-R
to me thats degrading the GT-R image
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4655374
good luck fitting the wheels!
anyway, VERY nice car Andy. wish i could afford one myself!
Haha, nah, it's a little joke between Andy and I. Told him not to put crappy wheels on the GTR! We know each other because of our STi ownership (ex for me).
From what he told me, the diffuser was stolen in Japan, and he's ordered a Top Secret diffuser as a replacement. The abscence of the carbon bonnet is a mystery..
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4655530
i was thinking more along the lines of the STi being 5x100 and they actually wouldnt fit the GTR :P
+1 for who cares about where the parts have gone. he is happy, thats all that matters!
exactly right.
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4656157
Andy sent me a couple of pictures of his car, and i noticed something strange:
His rear diff doesn't look like mine. Is it possible that his car is a non Vspec (without active diff)?
We're just trying to work out which exact model his car is. Is has Vspec II interior, but no bonnet or diffuser. Also his MFD doesn't display intake and exhaust temp, which i believe is featured on Vspec's...Hope i'm wrong for his sake!
Edited by Huy
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4685429
looks like it is not a v-spec II, the black interior is shared between the standard and v-spec II models from october 2000 onwards as are the N1 rear disc rotors so this is not really a way to tell the difference ,the MFD should have 7 parameters for a v-spec/v-specII/m-spec where as the standard model eg non v-spec will only have 5 parameters also check the tacho the 1 to 3 on the v-spec models will be compressed this is if it is the orginal speedo ,you can also check the code on the build plate look at the 6th letter it should start with GGJPRW the W means its a v-spec/v-spec II etc if it has a V instead of the W it is a non v-spec model
https://www.sau.com.au/forums/topic/274192-hiiii/page/2/#findComment-4688184
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
