Item: HSD coilovers to suit R32 GTR/GTS4
Age: 3 years old but hardly drove on em
Condition: good
Price: $800ono
To Fit: R32 GTR/GTS4
Contact: PM or email [email protected]
Comments: no need for these anymore cause im going full drag car
https://www.sau.com.au/forums/topic/274238-fs-r32-gtrgts4-coilovers-hsd/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
