ok people lately ive been more bored than ever so i need some of you to recommend some movies that i should download and maybe a little description about it too.
ill watch whatever but not anything too girly coz thats just what my sisters have on outside
thanks
https://www.sau.com.au/forums/topic/274320-movies/
  • Replies 45
i rent a tonne of movies plus my friends and i visit the cinemas regularly plus my friends have a huge collection of dvds so i just want some recommendations on what you think would be a good movie. i usually watch comedy and action movies but i do watch mainly anything aslong as its not boring
https://www.sau.com.au/forums/topic/274320-movies/#findComment-4651051
x 123456780000000000000000 good call
Yeahh the Warriors is a sick film..lol makes me wanna watch it again..
Also check out Donnie Brasco, Bronx Tale
or Heat with Pacino and Rob Deniro
https://www.sau.com.au/forums/topic/274320-movies/#findComment-4652362
Eiger Sanction
Black Hawk Down
Platoon
Dirty Dozen
Guns of Navarone
Where Eagles Dare
Dirty Harry
Magnum Force
Mad Max
Lethal Weapon
Ace Ventura
Super Troopers
Enemy at the gates
Great Escape
Gladiator
Schindlers List
Boondock Saints
The Departed
Blood Diamond
Raiders of the lost Ark
Indiana Jones
Good, Bad, The Ugly
High Plains Drifter
Fletch
Caddy Shack
When we were soldiers
Saving Private Ryan
Band of Brothers
https://www.sau.com.au/forums/topic/274320-movies/#findComment-4653241
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
