Hi all,
I have for sale:
Apexi front pipes for R32/R33 GTR (Off the dumps measure 2.25', at the cat measures 2.75', fitting has been attatched previously for oxygen sensor) $300
Nismo clutch pedal bracket to suit R33 GTSt, brand new $180
Nismo FPR to suit RB and SR setups, brand new $160
Tomei metal exhaust manifold gasket, brand new $80
N1 Oil pump gears, brand new $300
R33 GTR recirculation piping $120
GTR BOVs with mounting brackets $200
RB25 head (including cam, timing and valley covers) minus CAS $550
RB25 block, crank and crank cradle (number 6 piston blew a ringland) $150
R33 GTSt calipers, rotors and pads $550
R33 GTSt climate control unit $50
R33 GTSt diff (non abs) $200
R33 GTSt driveshafts (pair) $50
R33 GTSt front and rear sway bars $20
R33 GTSt condenser $50
R33 GTSt HICAS unit $50
Earls Oil cooler and relocator kit with braided lines to suit RB setup $500
Hawk brake pads for R33 GTSt, brand new. Front $100, Rear $80, Pair $150
HKS BOVs for RB26 $50
Motul RBF 600 brake fluid $15
B&M Oil cooler cores, brand new. Each $120, Pair $200
Stock R33 GTSt flywheel (will require machining) $50
Cooling Pro 40mm radiator to suit R33 GTSt/GTR, brand new $250
Parts are welcome to inspection.
Prices are negotiable to a degree.
I am located in Sydney, I am happy to post interstate at buyers expense.
https://www.sau.com.au/forums/topic/274379-the-anything-and-everything-sale/
  • Replies 47
Hi all,
I have for sale:
will you sell the hawk pads for 150 delievered to perth.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
