FS: R33 GTS25t S1. Manual. This car was featured in HPI Magazine 2008 then having a RB26/30, the original RB25DET has since been put back but with many of the RB30's bolt on's have remained. Has not since been dyno'd so cannot give a figure but would suggest well in excess of 200rwkw on current boost of 7psi. Has following mods:
-HD Clutch
-Malapassi Rising Rate fuel Reg
-Stainless surge tank
-700HP Rated Bosch 044 Fuel pump
-Trust front bar
-Trust Front Mount Intercooler w/ stainless piping
-GReddy Profec B spec II Electronic Boost Controller
-Microtech LTX12S ecu
-Microtech dash
-Apexi Pod filter no AFM
-GFB Trumpet Blow off valve
-HKS Billet Oil Cap
-Tomei Gear Knob
-Personal Steering Wheel
-Stainless oil catch can
-Turbo timer
-3" stainless exh.
-Blitz Nur spec muffler
-Autometer gauges, boost, oil and tacho w/ shift light (oil and tacho not hooked up as i read off the Microtech dash)
-17" deep dish lightweight wheels
-Sunroof
-95% black windows
-Bendix ultimate brake pads
I'm currently driving the car and it's spot on but will need a few minor bits done for RWC, please note that this car has had the A/C removed so if you live in a hot climate you may want to put it back on, however it saves a lot weight and I live in cold Victoria so doesn't worry me. Un-abused weekend driver and very clean for age and price. VIC Rego till Dec 2009.
**** Plates not included****
$14K
Ph: Miles 0414224905
https://www.sau.com.au/forums/topic/274475-1993-r33-gts-t/
  • 1 month later...
you ınterested ın a swap wıth cash my way?
the lınk ıs http://www.skylinesaustralia.com/forums/R3...od-t278827.html
cheers, taner
Nice GTR, unfortunately not interested in part swapping for a GTR at this stage.
https://www.sau.com.au/forums/topic/274475-1993-r33-gts-t/#findComment-4712219
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
