I have been given salvage rights to my car and looking to get rid of what is still 100%. If anyone has any questions dont hesitate to ask
33 calipers and rotors X4
32 GTR rear spoiler
32 GTR front lower lip
32 rear tail lights
Apexi GT spec intercooler
32 GTR fuel pump
32 GTR rear craddle(can seperate, has gtr diff and alluminium craddle bushes)
32 GTR Nizmo height adjustable shocks and springs
One piece tail shaft to fit between 33gearbox and 32 rear end
Apexi N1 exhaust from dump pipe back
RB25det engine (only been in one day) Not sure on head at this stage. Had done 30k before it went in
To4r turdo kit (has HKS cast manifold with twin external wasgates) can seperate
Also got another rb25det with head and inlet only $1500
Not sure what else till I start to pull everything down. Am open to serious prices no harm in asking though
Cheers Matt
https://www.sau.com.au/forums/topic/27457-expresions-of-interest/
really? I guess there goes that idea then, as those shocks are crazy, I can't wait to put them on - what a pain in the ass - looks like that idea is out the window Matt, sorry
Clint, is there any chance I can use the hoist to fit the shocks, i was gonna use my trolley jack in our driveway, but its a little dodgy - pm me if you want
ive also got the GTR shocks and spings to match, they are nismo hieght and damper adjust, id rather people pm or ring me if they want prices just incase the insurance company realise how much the car was worth even though it was burnt out thanks guys matt
