Hey mate, i had a 97 NA a while ago, tried to do some tuning and found the best mods are:
stock airbox with panel filter, high flow cat with an exhaust if you like the sound and keep your maintenance up (oils, plugs etc)
jst as a downer, i pop'd in a unichip and dyno tune to push out 78awkw which was quite dissapointing but tuning does pick up about 10kw in the low to midrange area if you have the cash to spend.
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4655264
ay ay ay...no mudslinging please.
LOL!
Welcome to eeiko321's world.
GTS / GTS-T hater! No mater what model.
:dry:
For a 1st mod for a R33 GTS, I would go modified extractors, full 2.25" exhaust with high flow cat.
Leave it as that, or you can go cam gears, cams and internals but I would rather save the cash for buying a turbo model.
Upgrade your springs / fully adjustable suspension would help with handling.
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4655581
LOL!
:dry:
exactly, not a big GTS-T or even GT-T fan at all
but yet, i have not entered any thread and implied to the owner that your car is a loser's car... especially when this bloke asked a genuine question.
so i dont regret what i typed to this "noob cake" at all..........
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4655605
LOL!
you should bolt on a turbo. seccond hand parts go for a bargin te days
I can say it is not that simple and there is a lot of work involved.
When you add one thing to the car to all leads on to the next.
Best sell the N/A and buy a turbo.
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4655677
LOL!
+1....
and how do you know this guy or girl is even allowed to drive a turbo car for the next 3 years?!
what an idiot reply.........
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4655966
Point was made earlier in the thread (wihout resorting to insulting anyones car, no less.)
The most likely reason that this person wants a lil more out of their NA...is not because they prefer the GTS to GTST or GTR...but for legal reasons. P-plate laws are harsh.
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4655984
i cant get turbo til im 22which is in 4 years
i just bourght it cause it looks good and has some go for a N/A, but nothing to get excited about
Victorian?
Feel sorry for you, my friend. Least i got through on the last set of laws =D
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4656092
well, no need to tell me that.............
refer to "Noob Cake"'s reply ......
you should be telling him that
https://www.sau.com.au/forums/topic/274590-first-mods/#findComment-4657754
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
