used for about 4 months now, still in near perfect condition, not the current line but the one before that with the uncoated tweeter, it has been warn in now so it sounds beautiful. will post pics soon, will come in box and have manual if i can find it ... bidding starts at 200 .. selling as i got some JLs :)
pics here ;)
http://www.users.on.net/yauipop/speakers/
https://www.sau.com.au/forums/topic/27462-fs-65-focal-polyglass-splits-165v/
well yeah i would consider focals better than JLs too .. but not when u compare JL XRs to focal polyglass ... i mean the top of JLs range to like the almost bottom of focals range :) .. the rrp on the JLs are like 900 whereas the rrp on the focals are like just under 500 i think .
Originally posted by hippy
well yeah i would consider focals better than JLs too .. but not when u compare JL XRs to focal polyglass ... i mean the top of JLs range to like the almost bottom of focals range  :( .. the rrp on the JLs are like 900 whereas the rrp on the focals are like just under 500 i think .
oooo.....nice!!
good luck with the sale man!!
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
