  • Replies 46
This is my Pedders experience.
Had the wheel alignment done on my R33GTS-T and it came back with a large scratch in the left rear quarter panel - which they obviously denied doing. Had a great fight with them when I asked them to use Gary's (Sydneykid) settings for the wheel alignment - they did it but with much complaining and probably resulted in the scratch.
Prices are very expensive - 12mm camber bolts Pedders = $115, Whiteline $79
The only thing going for them is that they stock front ball joints for R32/R33/R34 GTS-T's.
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826267
so they measured up my car to see how much lower it will be with there sports ryder springs. (i have nismo s type struts and an unknown but firm spring, that i figured was stockish height)
aparently they will raise the car 10mm both ends. wtf type of lowering spring is that!!!
*starts saving for coilovers* (not pedders)
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826489
meh pedders here don't even stock more than about 4 parts for R32 GT-R/4 suspension and the guy took a look at my car and says 'hmm haven't seen many of those', would rather get stuff done at goodyear - at least the guys there had a good idea of how an R32's suspension works!
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826585
  • 11 months later...
Hi all, first time poster and owner of a skyline R34. went to get it looked at by a local mechanic coz the steering wheel was vibrating a bit on idle. He said I needed to get the front radius rod bushes replaced and suggested I go to pedders coz it's an import.
So I go to pedders and got them replaced for $260 but then they told me that they couldnt do the wheel alignment coz the steering gear is leaking internally and will cost another $1100 odd dollars to fix.
Just wanted to know if this sounded reasonable and should I be looking around elsewhere to see if it is bull. Can anyone recommend someone in melbourne, particularly in the western suburbs?
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-5428632
No it's not reasonable. A second hand steering rack should only be 300 or so, and it isn't that much in labour to install. Also, I can't see how a leak would prevent them from doing a wheel alignment. Just go somewhere else to get the alignment done.
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-5431439
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
