1991 kps13 Silvia
Sr20de
5 Speed manual
viscos lsd
Mods
Exhaust/Engine/Driveline
4 into 1 Jasma extractors
2.5" De-cat pipe
2.5" D&T cat back exhaust system
Drift pod filter
New genuine Nissan water pump- fitted March this year
Serviced every 5000kms
KTS poly gearbox mount
Xtreem heavy duty clutch- 12 months old
Suspension/Steering/Brakes
ISC coilovers
Whiteline heavy duty adjustable swaybars
F+R Cusco strut braces
New tie rod ends- Fitted March this year
New steering rack boots- Fitted March this year
Super Pro lower controll arm bushes
Slotted front discs
EBC Redstuff front brake pads
New rear disks- Under 1000kms 0ld
Qfm rear brake pads- Under 1000kms old
Non Hicas rear end- Fitted 1 month ago
Interior
Velo bucket seat
s14 passenger seat
Drift steering wheel
Nismo look-alike gear knob
White face dials- Light up blue
Dash mat
JVC cd player
JVC rear speakers
Sony front speakers
Exterior
Vertex bodykit
18' Lenso Passion wheels
Clear front corner lights
Fibreglass bonnet- Painted matt black (pictured in bottom photo)
Spot lights- Mounted inside front bar vent
Spare Parts
Metal bonnet- In original green colour
Fibreglass boot- Needs painting and fitting
Spare r200 vlsd
s14 Drivers seat
Standard exhaust manifold
Standard cat
Regency spec exhaust
4x stockies
Complete boot trim- Will put on if wanted
Price- $10,000 with everything listed
$9,000 without fibreglass boot, bonnet (will put original back on), Velo seat (s14 seat will be put in), spare diff
Very firm on prices
will consider swaps for dual cab Hilux or Rodeo 4x4
https://www.sau.com.au/forums/topic/275164-silvia-sr20de-manual-adelaide/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
