THOUGHT I'D START A NEW THREAD ON MY CAR.
PRICE DROPPED TO $19500 FOR A QUICK SALE. THIS IS A BARGAIN PRICE FOR A CAR LIKE THIS, PLEASE DON'T WASTE MY TIME WITH LOW BALL OFFERS AS IT IS ALREADY VERY CHEAP
Reason for sale is that I want to get back into forest rallying and I cannot afford to keep the Skyline. I would if I could! I have purchased a rally car now too.
The car has always been garaged and religiously serviced (I am a mechanic) every 3000km, using Castrol products. Always warmed up/cooled down. The car has never missed a beat and has been a pleasure to own, modify and enjoy! It has never been in an accident - any inspection welcome!
It has travelled 64500km.
Engine mods:
GCG steel wheel ball bearing highflow turbo
Power FC
Greedy boost controller set at 14psi
Walbro in tank pump
Sard fuel reg
Nismo 480cc injectors
Splitfire coilpacks
Drift pod filter, cold air pipe and underbonnet heat shield
Monsta front mount
Full turbo back exhaust, high flow cat and HKS rear section from cat to tip
Poly (hard) turbo intake pipe instead of standard soft rubber pipe
Tuned by Micks Motorsport to 230rwkw
Just Jap alloy radiator and twin thermo fans
Genuine Nismo low temp thermostat
Oil catch can
Brakes/suspension mods:
Nismo S tune suspension with 4 way adjustable shocks
Just Jap radius rods
Just Jap upper rear camber arms
Just Jap HICAS lock bar
QFM A1RM pads all round
Master cylinder stopper bracket
Lucas racing brake fluid
Street legal braided brake lines
Interior is standard and in excellent condition. I have never smoked or allowed anyone to smoke in the car. Has a full set of factory mats.
Only interior mods are a Saber boost gauge and Nismo gearknob.
YLD34T number plates included and registered until September 2009
2 brand new Kuhmo front tyres fitted and 4 wheel alignment carried out
Will provide a pink slip to NSW buyer
PRICE: $19500 o.n.o
Please call Toby on 0409 903 669 for more information.
Attached thumbnail(s)
Reduced 91%
1600 x 1200 (862.58K)
Reduced 91%
1600 x 1200 (826.9K)
Reduced 91%
1600 x 1200 (835.38K)
Reduced 91%
1600 x 1200 (819.67K)
Reduced 91%
1600 x 1200 (731.14K)
Reduced 91%
1600 x 1200 (886K)
https://www.sau.com.au/forums/topic/275290-230rwkw-gtt-19500-bargain-must-sell/
wow you have had this car for sale for ages and on carsales, had many inspections? anything wrong with it?
I have had 2 inspections and a lot of "interest" but no sale as yet.
THERE IS ABSOLUTELY NOTHING WRONG WITH THIS CAR - I am puzzled why there hasn't been more interest and a sale!
$19500 is a bargain for my car. I have spent many thousands of dollars and countless hours of my time modifying as I'm sure you can appreciate.
Have you thought of parting your extras? You could probably still sell your car at the asking price with a bit of bonus cash from the modifications~! Really I'm just a vulture and would love to have your modifications in my R34 haha
I thought of it for about 2 seconds.....the car is the car that it is BECAUSE of the mods performed.
I'm sure someone will see the value in this and buy it sooner or later.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
