can you please post pics
Sorry still on car at the moment upgrading to 165mm is reason for selling
call me at a reasonable hour if you wish to see or discuss it.
Justin ph:0414894884
FOR SALE:TRUST/GREDDY INTERCOOLER
CORE SIZE:H302/L710/115W
END TANKSfitted with same as standard plenum diameter (85mm)
CONDITION:PERFECT (LOW KM's made 428rwkw on street tune 98RON)
PRICE:$1200ono (cost was AUD $2660.62)
"UPDATED"
END TANKS:Trust end tanks fitted same as standard plenum diameter (85mm)
  • 3 weeks later...
"UPDATED"
BUMP!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
