Fitting an exhaust myself today. It's a full turbo back system.
Just wondering how much boost will I be running? And is it safe? Everything else is stock.
I don't have a boost controller yet and I don't want to risk decimating my turbo.
I didn't think it would be an issue since R33's only run 7psi standard and I couldn't imagine it leaping high enough to cause damage. But best to be safe.
I tried searching but this is urgent.
Cheers
https://www.sau.com.au/forums/topic/275651-quick-question-about-boost/
have u got a boost gauge? your right they run 7psi stock (this is after 4500rpm, before that its 5psi) but they tend to run up to 9psi after upgrading the exhaust and cooler, this is normal & safe
technically speaking the boost shouldn't actually rise at all. this is because the boost is controlled by the wastegate and it will still open at the same pressure. i never saw a boost increase from full exhaust and cooler. however other people have.
I just have the standard boost gauge in the dash. So I have no idea.
But thanks for the information everyone... It helped massive.
My mate fitted it all today after eight bloody hours. Got him to do it as he is in the trade and knows more about the right way to undo and tighten bolts. Took so long as there was a few brick walls to jump when fitting.
Not a fan of the system. Way too loud... It drones under load so much it hurts and it does not sound like a RB anymore if that makes sense.
Hopefully it is worth the performance after I give it a bit when it wears in properly.
what sort of exhaust did you get for it to be super loud? i had a 3" off the turbo to cat then 3.5" from cat back and it wasn't very loud at all.
does it still have the centre muffler in it?
as for it taking 8 hours, wow. i'm guessing a broken bolt/stud on the turbo, because otherwise it is a very straight foward job and shouldn't take more than about half an hour.
It was the full JJR system with the Xforce Cat. It is the loudest I would go for an exhaust in this car but the only problem is that it drones under load. Can hurt the ears. There is no centre muffler with this system.
It took so long because one of the bolts to the turbo was pretty hard to get to. We didn't have the right tools to reach it and the bolts thread was slightly stripped. And the who ever welded the cat was the worst welder. They left a blob right where the sensor goes so we had to drill it out to get it to fit.
If it all went smooth then it would have taken half the time. Oh and we got Macca's so that took up time haha.
I will give my final thoughts on the system once it wears in a bit. For the price it's still a great buy regardless. Just wish it sounded a bit more smoother.
it is probably due to the rear muffler they use. the body of the cannon probably isn't quite big enough to allow enough packing between the baffle and the outer body to take enough noise out of it. also being stainless probably makes it a bit louder. if you still don't like it in a week or 2 just go to an exhaust shop and get a better muffer put on, like a large 3" oval muffler such as a lukey ultra flow. that will make it a fair bit quieter.
+1
Yeah that sounds like a good idea. But I might start catching the train to work so this will be my weekend car soon enough. I will be more reluctant to put up with it.
You are right about the stainless part. Never been a fan of stainless compared to mild steel as far as sound goes.
there is a huge difference between stock and aftermarket exhausts mate, dont worry you will get used to the noise and learn to love it!
  • 5 weeks later...
Yeh had the same system and im not sure whether it wore in or i got slightly deaf.Either way sounded awesome on boost.Actually have it from catback still in the garage if anyone is interested.Its also had a hotdog resonator welded in but the resonator is in mild steel.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
