Hey guys, well I'm looking at upgrading my turbo so my current turbo kit is up for sale. Sorry but it's still on the car and I most likely wont remove it till I have a legitimate buyer as Id like for the car to be mobile for as long as possible. I had the turbo off a month ago and it is in tip top condition with minimal shaft play (only the usual slight play all run in turbos have). It is a super punchy turbo kit with huge midrange pull and currently makes 230 rwkw on my sr. Also I am willing to freight. The kit consists of the following:
apexi abx5370 turbo
braided lines for water and oil
custom alloy intake pipe
manifold heat shield
hpi low mount stainless manifold
apexi dump pipe
Price = $2000
contact in here or via PM
Sorry but this is the only picture I have on this photo and it shows practically nothing, I will go and take some more tomorrow with the heat shield off
https://www.sau.com.au/forums/topic/275771-apexi-abx5370-turbo-kit-for-sr20/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
