Hi all,
A mate has busted the drivers seat in his R33 GTR. He is a 120KG muscly fijian lad and the seat just couldnt cope trying to hold him in when cornering I guess. The seat back has stress fractured and snapped center console side just above where the pivot is.
There seems to be a shortage of good condition R33 drivers seats around, but Ive tracked down a few passenger side ones. Has anyone ever tried swapping the backs over on seats to repair them? If it fits it might be an option to repair his seat using parts from a passenger seat rather than buying a pair of after market ones.
https://www.sau.com.au/forums/topic/275981-r33-gtr-seat-repair/
To be frank I think its much more likely that the car (or at least that seat) has been in a big accident previously, a big bloke isn't going to break it alone.
I am 99% sure the seats are the same other than the rails underneath, so it must be possible to cut and weld the correct ones across. Or just find a drivers seat as it may still be cheaper due to the cost of proper fabrication. Or pick up some aftermarket driver's seat
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
