Ok, as the topic says....
Item 1: RB26 Sard Fuel Rail. $350 ONO.
Rail was purchased from another SAU member as a package with injectors. Prior to purchase i was assured that both injectors and rail were matching, however upon arrival i had been stooped... (10.5mm injectors and 11mm rail). Using standard rail now, so i have no use for this. I have never used or fitted this to an engine and i believe the previous owner hadn't either. (see pics, it's pretty much new). Comes with bolts and injector washers as seen in pics. Suits 11mm Injectors.
post-29915-1245748949_thumb.jpg post-29915-1245748956_thumb.jpg post-29915-1245748961_thumb.jpg
Item 2: JJR480 Turbo. $750 ONO.
Turbo was purchased from Just Jap over a yr ago to use on r33 rb25, however changed direction and that car was sold with standard turbo. This turbo was dummy fitted on a h/mount manifold (so compressor housing rotated) but has never been run at all, just been sitting around in the in box). Turbo is oil cooled and has split t3 flange to suit rb25, comes with t3 gasket, banjo bolt, oil drain gasket. (see pics).
post-29915-1245748914_thumb.jpg post-29915-1245748924_thumb.jpg post-29915-1245748932_thumb.jpg post-29915-1245748941_thumb.jpg
Located in Bathurst NSW, pickup preferred but can post at buyer's expense. (will be in Sydney 26-28th June if anyone there wants the items free of postage).
Contact Via PM please.
Thanks,
G.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
