GSL RallySport Stocks the complete range of Project Mu High Performance Brake Pads, Disc Rotors, Caliper Kits and Accessories!
Brake Pads
Project Mu has a complete range of brake pads, from high performance street and weekend track, right through to motorsport pads suitable for Porsche Cup, and V8 Supercar Control List!
For more information on which pads are best suited to you application visit the Project Mu Brake Pads Website or contact GSL RallySport on 1300 884 836!
Disc Rotors
Project Mu offers everything from slotted street replacements, through to 2 piece race rotors. All Project Mu rotors are made from high carbon cast iron and have a high ability to pump air and therefore cool quicker. Their unique vane design allows large volumes of air to pass through offering more stable disc performance at higher temperatures.
For more information on which disc rotors are best suited to you application visit the Project Mu Disc Rotors Website or contact GSL RallySport on 1300 884 836!
Caliper Kits
Project Mu has bolt on caliper kits to suit most Japanese models! All kits include calliper, calliper aluminium brackets, brake pads, rotors, teflon brake lines, all bolts!
For more information on which caliper kits are best suited to you application visit the Project Mu Caliper Kits Website or contact GSL RallySport on 1300 884 836!
  • 3 weeks later...
*** Special Limited Time Only ***
To compensate for QFM currently having no stock of Skyline A1RM pads, we're offering 10% off AND free shipping on all Project Mu pads, rotors, calipers fluid and accessories. Get in quick as this offer will only last until we get A1RM pads back in stock!
  • 4 weeks later...
hey mate,
whats the cost for a set of handbrake shoes for a r32 gts-t
cheers ash
Hey there,
How much for front and rear rotors for R34 GTR shipped to Melbourne?
Cheers
Jason
Hi Jason,
Unfortunately Project Mu don't make the entry level rotor for the R34 GTR, so you need to jump straight to SCR.
The SCR is $839 for the front pair, and $759 for the rear pair. Shipping to Melb would be $15.
Regards,
Greg
*** Office Closure 31/8 -> 7/9 ***
GSL RallySport will be closed from the 31st August through till 7th September due to our involvement in the World Rally Championship. All orders would need to be placed and paid for by Wednesday this week to guarantee delivery. Office re-opens 8am 8th September.
For all the information on the WRC checkout http://www.rallyaustralia.com
Apologies for any inconvenience caused!
Best Regards,
GSL RallySport
  • 1 month later...
Project Mu October Specials On Nissan Rotors!!!
For the month of October, we're having a special on Project Mu rotors to suit Nissan vehicles! If we run out of stock, you can order and pay for your parts in October and still receive the special prices. Delivery will be mid - November. All prices are per pair, full details on the rotors at http://www.project-mu.com.au/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
