With rev limit 8000rpm... does it use the column N19 or only N18?
Also see my base map please... this is with recalc base...
N19-P20
N20-P20
It isn't logical to be so low right? It must be more than N18-P20 right?
Why I ask all theese..
My car run 2bar-30psi and I don't have datalogit right now to tune anything in my car...
As I run this boost I only intersting for row p20 and cells from n13 to n20.
I run the car with rev limit 7500... it was ok 10.8afr! I run it 8000rpm... again ok 10.8!
But ofcourse at theese rpms with so fast car it is different to see the gauge and understand. Also the last rpms before the limit you cannot understand if the numbers are from rev limit or the afr from last rpms.
So I want to tell me if the map seems to be ok to theese cells or in theory the car will be very lean if it will read the N19-P20,N20-P20!
Remember in the foto is recalc the base.
My guess that theese cells must be 40 and 42 is right?
Also the car take out oils at theese boost.. I undestand it because I don't have oil catch can and the oils goes at the turbo and many smokes suddenly filling all the car haha!
The first time my heart stop for some seconds to work!!!
https://www.sau.com.au/forums/topic/276234-power-fc-tuning-help-questions/
i really need to see both fuel maps: feel free to email me the map info@statustuning.com i will have a look over it and do a few adjustments if neccessary. Generally speaking if the map ponts in the main map are linear accross the rpm points then yes the N19 and N20 points you have highlighted should also be linear (increasing) not decreasing.
Edited by URAS
URAS so you mean that N19 and N20 must be sure more than N18 right? So more than 39... and now is only 25!!
With 8000rpm limit will be lean the last rpms??
In the foto I have recalc the base!!
You have two emails :)
paulr33
Thanks for the tip... I wish to know it earlier :)
just emailed the maps back, i had to make some big changes so you will need to reload them via datalogit and check AFR's the original fuel and base maps were full of big holes.
Edited by URAS
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
