They will not fit into the existing bracket... I know because I fitted one in my car last thursaday...
They are about twice the size of the stock pump, so you will need to alter the bracket...
also the top nut fitting is a different size...
AWESOME PUMP THOUGH....sounds sweet and works a treat.
Dan
I paid $215 dollars for my pump (part no 0 580254910-390)
You also need new fuel filter (for warranty reasons)....
I bought it online from www.onautos.com.au
The guys name is Trevor.... delivered to my door in 4 days.
My machanic fitted it and I helped...
Dan
if you are a hack machanic I dont recommend it..
If you get it wrong.. bye,bye motor....
Dont risk it... my machanic put it in for me for $60.... and that also included change oil,plugs, filters...... BARGIN, he looks after me....
Dan
bosch 390 can fit into the std bracket it you modify it though. i know some pumps are WAY too big and need a completely new bracket to fit...
is the 390 overkill?? im only after a 400hp pump... and with replacing the ful filter i just did that on my last service... do you need to replce it again or do they just say have anew filter present cos mines less than a week old!
ok i rang a performance tuner here in perth, they reckon no bosch pumps will fit the std bracket and to fit a 390 you would have to go for a surge tank setup....
i might investigate the possibility of using a GTR or VL pump, does anyone know of anyone whos used these?
I made a 044 pump fit in the stock bracket and it is the biggest pump they make. You have to moddify the bracket a bit and it only justs fits. Have a look at the 040 i think it is, it is a little smaller and is designed to be mounted in tank as it has the filter in the bottom of the pump, good for 400hp easy. The 044 requires the sock filter off the stock pump to be fitted to it. Get the biggest one you can afford to fit as you will be sure it will do the job, only paid $400 for the 044 so shop around to find a good deal.
Fuel pumps dont have a HP rateing !
They have a L/hr at x presure graph.
Bosch 040 Been useing a lot of these
Bosch 044 and these.
Bosch 975
975 is same as 044 but hand made and assembled and has threaded fittings, and is expensive !
The 040 and 044 can be made to fit in a standard GTR pickup situation, GTS-t same ??? i think so.
E
Adam you dont need a surge tank with the 390... all you do is buy some bigger fuel risistant tubing and by-pass the standard "small" fuel hoses in the tank.....
You will also need to put in NEW fuel filter with pump to keep warranty.....
Dan
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
