hey all got some stuff i need to get rid of
Bride Zeta 3 fia approved type L graduation print with ultra low rail model no45 suit s13,14,15 r32,33,34 looking for around $1100
Nismo rear strut brace suit r33 $140
Apexi black turbo timer hardly used $70
nismo gearbox mount suit r33 gtst model 11320 rsr40 brand new in box $100
Cheers Andrew
if the rails fit silvias more than likely they wont fit skylines.....i kno its a skyline in the pic but can u get pics of the mounting holes that go to the floor?
incorrect, if it fits silvias it will fit skylines. it's only one of the rear feet that doesn't match up with one of the holes, the other 3 mount points are the same. some rails come with holes on the rear foot to accomodate both skyline and silvia these days anyway
hence y i sed it doesnt fit
how muchfor seat alone?
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
