hey guys
just a question if i replace my rb20 redtop with a rb20 silvertop or even might be thinking of a rb25 (engine, gear box, ecu & loom) will i have to get the engine tuned to suit my hr31 passage if it comes straight out of a running r32? or will it still run fine?
also are there any mods i should know about to do the conversion?
cheers for the help guys
tune on the stock ecu will be fine. tis a bit rich but its fine.
its fairly straight forward. trickiest part is usually the wiring, but theres only a few wires. theres a guide on www.r31skylineclub.com somewhere
I would be using the loom and ecu from which ever motor goes into the car... and at the moment there is an RB25 from an R32 being sold by Phantom32 or something like that for 1500, and a mate paid 1200 for a silvertop recently... which is better value :)
can i reuse my original loom thats in the car already? for either a rb20 or rb25??? or are they both different?
cheers
use the loom to match the motor. when you buy an engine package the loom should still be all hooked up, drop it in the car like that and feed the loom through the passenger side guard area into the passenger footwell.
Removing the loom is easy. Take the passenger side kick panel off, disconnect the ECU and take out the ECCS/Ignition relays.
Then you can feed the loom back out through the firewall and into the gaurd, then pull it through into the engine bay and remove. Silvertop loom is just the opposite, connect it all up to the engine then feed the ECU connector and relays into the gaurd first, then into the car.
The wiring is straight forward, check out the guide on r31 forums or PM me as I have done a couple before.
ok thanx heaps mate
i take that as the looms are different from the redtop to silvertop?
will pm you if i get stuck thanx heaps
Yes the looms will be different, sensor types/locations vary. The major difference is between NICS and ECCS motors, but there are even differences between redtop ECCS and silvertop ECCS.
Good luck PM me if you get stuck.
  • 4 months later...
Hi everyone. I have just bought a hr31 and wanting to convert to silver top turbo. Just wondering if you have to change all wiring to the dash and a/c or is there just a connector from engine bay to interior wiring so its just the engine bay wiring and ECU that has to be changed? Thanks guys. Sorry this might sound stupid as you have already told how to do it but it just sounds way too easy lol.
Edited by sr_esky
theres a plug down in the passenger footwell where the engine loom joins the body loom. obviously different from 31 to 32 so you need to hardwire a few wires (tacho, temp gauge etc). theres a guide on www.r31skylineclub.com
or there is a guy named kev in r31skylineclub that mods the loom to suit your cars needs plug & play...
not sure on his user name tho.....
Cool, thanks guys. Have been looking at that site and they have manuals for rb30 r31's. Not to be a pain in the a hole but is the body wiring in the gtsx the same as the body wiring in a standard r31 4 door with rb30? Just different engine wiring from that plug?
give kev a call mate tell him what you want done & he will do it pretty cheap to :blink: his number is 0738144674
import is different but still the same procedure. the small brown plug down near the ecu is the body plug on the hr31 side, all the wires you need to wire up are in that plug
Thanks for that. Just wondering where kev is situated? Im in perth so if he is anywhere else then it might be a bit hard or does he supply pre-made looms or diagrams?
he is in brisbane but you could send your loom to him & he can make it you just need to send him a pic of the plug inside the car, just call him & work something out with him mate....
to do that you'd have to figure out which wires are which for him to make a plug, thats the hardest bit of doing it anyway. once you've figured that out you just solder them together and away you go. theres no diagrams or pinouts for the hr31 side of the loom anywhere on the net, you have to figure it out yourself or find someone whos done it before who can be bothered checking for you
as i said kev makes the loom so its plug & play
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
