Hi there i have these 19" rims for sale $1300, gold coast pick up only! Has tyres in pretty good nick. Will swap for really nice 18's with good tyres. Post picks of possible swaps. i apoligise if i am picky. swaps obviously within driving distance....Rodney Jane Racing is the brand......
https://www.sau.com.au/forums/topic/277271-19-crome-wheels/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
