i have noticed that i have a low beep about 2-5 min after starting my car it comes from around the center may above the cd player just on beep ive herd one like it before but that was when i turn hte car of but leave it on acc say while the wife goes in to a shop and i wait in the car with the cd playing id hear 2 beeps about 2 sec apart any idears what it could be cheers
mark
https://www.sau.com.au/forums/topic/277764-beeping/
try this:
take wife to shops - leave CD player OFF. if the beeps still happen its coming from the navi.
the radio will beep if it has a fault. that will eliminate one of them.
Edited by Chris Rogers
https://www.sau.com.au/forums/topic/277764-beeping/#findComment-4696401
i get the same beep
single deep, however
and its def from the navi system
If you have your JAP Sat Nav disk in the DVD-Rom. after start car for 2-3 min, there will a deep come from the right hand speaker tell you that the GPS is ready to us( With JAP map of course.).
Is that the one?
Frank
https://www.sau.com.au/forums/topic/277764-beeping/#findComment-4700315
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
