hey putting car up for sale as iv now lost my license for 6 months and there is no need to have it sitting around car is in good knick 17500 cash no trades as new law about impounding car while driving on suspended license makes driving to risky
Year 2000 DC2R YELLOW
mileage : 170 000km
DC2R MOD LIST:
JIC MAGIC FLT FAS adjustable coilovers
Buddy club P1's 16x8 +35
Yokohama Advan Neova AD07 195/55r15
EBC Yellow Brake Pads F & R – 0deg to 800deg ( Track spec )
ARC intake
Energy Suspension Engine Mounts
Exedy Sports Organic Clutch
Fidanza 3.7kg lightweight Flywheel
5Zigen Pro-racer A spec Cat-back exhaust system
Hytech Tri-Y Header
VAFC2 – tuned by Zac from Cypher 170.3hp atw at Tenagah Dyno
6000K H.I.D
Skunk2 gearknob
Dvd Player
20% tint by TKO
Serviced with Motul Engine Oil very regularly every 3000-4000ks
New gearbox Oil
New NGK spark plugs
New o2 sensor
New CV joints
New power steering + aircon belt
New rear main seal
https://www.sau.com.au/forums/topic/277815-2000-honda-integra-type-r-wa/
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
