Resurrecting this thread again as ive started a S1 build. So far ive found:-
Rear speaker mounts (plasic bits) are different. Fronts are the same
Door mirrors are different...the outer bit that moves when folding apears the same but the part that bolts to the door is different.
Front and read screens are different
Rear bar and pods are different
Areals the same but the bracket on the botton is about 2mm different length
Boot plastics. Sides and rear are different. As is the brackets o the tail lights that mount them..I dont have a floor to tell yet. Battery covers the same but
Parcel shelt is about an inch amd a half deeper
Rear seats are different but can be made fit..I replaced the panel behind the seat with a coupe one (had to straighten it somewhat but it gave me the height of the hooks the back of the rear seat locks into). Then drill out the spotwelds of the 2 outer hooks and rerivet to the new height...coupe back seats are a bit narower to so youll have a 10mm gap down each side.
S2 coupe headlights drop straight into the S1 sedan (weird cause they dont fit properly in a S2 sedan)
Coupe locks can be used all round but the boot lock needs to be striped down to just the barrel
Carpet. The only difference is the location of the strips on the side rhat hook on and the coupe has the 2 holes where the front seatbelts attach to the J shaped bar thingy
Rear wipers are interchangeable to
Thats all I can think of for now....
PS my dash harness was hacked up so ive put a coupe one in...tail lights, blinkers, interior light(triggered by back doors), rear windows and areal etc worked. But central locking needed wiring in.
  • Like 1
  • 3 months later...
  • 4 weeks later...
anyone know if the rear seats are the same as 2dr?
No coupe seats are about 15mm smaller each side and the mounts for the top half are different (the are easy to modify but)
Panel behind back weat is differet to, flatter (can be swaped for above with work)
Exhaust will fit but a bit shorter
Bracket on the bottom of areal is different
Most boot trims are different. Gap between lights is smaller
Parcel sheld if about 25mm deeper
Rear speaker pods are different but fronts are the same
Only difference in floor carpet is tye clip/chanels down the sides and the coupe has 2 holes for the bottom of the seatbelts
S2 coupe headlights droped straight in my s1 sedan
S2 coupe front panels went on my s1 sedan no dramas. Even used the s1 reo and got everything to line up
Rear cradles are definitely the same
Rear pods are longer on the sedan
Coupe wings (drift,normal and M spec) wings wont fit
Front and rear windscreens are very different
Dash and centre console are the same
Front seats are interchangable BUT sedan seats dont flip foreward in one hit like coups do...and sedans have adjustable lumbar support instead of adjustable wings
Rear bars are different (longer)
Dash harness is different (missing a few wires for the rear doors). I put a s1.5 dash and front harness in my s1 sedan. Can be modified to work if your desperate.
Front passengers window switch is swapable as is the handle it mounts on
Pretty sure the roof lining is different (windscreen shape) but I cant confirm as I havnt swaped em
Roof wings are different
Diffs are the same between short and long nose..ie a short nose coupe diff will fit a short nose sedan setup
That's all I can think of atm
  • Like 1
Hello,
I have just bought a R33 sedan, that needs a few things, i'm wondering if anyone knows if the sedan and coupe share the same of the same items:
S2 Bonnet
Interior A piller trims
Front seats
Thanks!
S2 coupe bonnet will fit a s2 sedan but for a s1 sedan you wull have to change the grill and better to do the bar and headlughta or it just dont look right
A pillar trims are completly different (I might have some in a couple of weeks at doyalson nsw)
Front seats...short answer is yes but see above post
  • 1 month later...
  • 4 weeks later...
Regarding the mirrors, if you need to replace the mirrors on your sedan, make sure you keep the base plate (the part that bolts to the door). The rest of the mirror is interchangeable.
So when replacing, you will need to unscrew everything and butcher the wiring to remove and replace the base plate. Use crimp connectors unless you dodgy like me and you individually twist/wrap and bind the wiring.
  • Like 1
  • 1 month later...
U mean using coupe mirrors on a sedan?
the outside bit yea..you have to use the triangular part that bolts to the sail from a sedan but the guts (motor glass etc) and the outside shell are the same..i had trpuble gettimg sedan mirrors that fold in and out. Just pull em apart and swap the triangular bit and your good to go
Ganadors dont sit right on a coupe anyway...my mates got em and personally i think the fitments crap. Hangs over the window opening by 15mm or so..maybe with some work theyd fit right..but depends hownkeen you are :)
Edited by BundyBear
  • 1 month later...
So I've done some looking this seems to be the best thread for my question and I can't se a direct response anywhere either. I have a S1 334 door and want to fit a cage, will the cages for a 2 door fit, it seems form what is said here that they will, but cusco used to make a 33 4 cage, now discontinued. I'd like the back seats to be accessible, even if impractical. Anyone got some info or tech on this, or if ceffy or other model cages fit?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
