Hey guys im sellin my volk GT30 wheels with tyres. wheels are nearly 2 months old and been on car for a month. im sellin them as i dont have use for them
i paid 1300 per wheel and selling the lot with tyres for 5500.
Details of the wheels
Volk GT30 with 84mm of dish, center is gun metal grey 19 x 9.5 with +38 offset
Khumo 275/35/19 tyres with 95% tyres on them
Wheels come with orginal boxes and center caps (carbon fiber ones)
Volk racing wheel nutes with lockin nuts
Will post pics up asap
Nick
0432733357
I've seen people spend more $ on a stupid paint job or stereo installs at auto salons for which they will never be able to enjoy their car as a daily driver. Each to their own. Jap wheels are an acquired taste which few people appreciate. Speak to some of the R35 owners, they are spending in excess of 10K for 20" wheels imported from either Japan or US.
Being 19s + brand new tires they are fairly priced. Whether he will get that depends on who the buyer is.
Stop spamming his thread with useless comments. I wouldn't put BJT wheels on my car even if you gave them to me for free brand new.
GL with the sale Nick, if the fronts were 8.5 I would have been keen.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
