  • Replies 130
Posted Images
Hi,
Did you end up getting the money for the suspension?
Yes, the suspension is sold.
Was the entire front end caved in? after the drives side front parker light
Front parker light is ok, pm sent.
hey mate i havent been able to reply for some reason kept coming up with flood control and said i had exceeded my PM limit.
thanks for the seat belt, dad brought it back the other day, now i just have to get a round to installing it.
also dad liked your car, said basically it was the same as mine. i hope he didnt waffel on for too long when you dropped off the part. cheers mate. :D
also dad liked your car, said basically it was the same as mine. i hope he didnt waffel on for too long when you dropped off the part. cheers mate. :P
Hey Damo
Yeah, we talked about cars for a while, he said you had a red S1. Looking at the pic in your profile, you stag looks identical to mine before the mods. There's a pic of it here (Post #177) http://www.skylinesaustralia.com/forums/Po...=pic&st=160
dan
whats the going rate for one wheel bolt, the rear wheel cover???
Hey Adam, how does $30 for the wheel bolt sound, oh and I'll throw in the rear wheel cover for free.
Cheers
Hey Damo
Cheers
yeah i got a couple of photos in there somethign lke the second last post.
i havent touched mine but at some stage i plan on changing at least my front bar. but yeah mine is basically stock apart from the GTR FMIC. oh and our wheels a simular, but mine are autech rims.
when i get some time ill PM you some pics.
hmmmmmm just need to give it a good polish.
Here are a some pics of the gearbox. It comes with the clutch slave cylinder, bell housing bolts and gear knob - $1000
Manual conversion parts, includes everything that's in the photo, clutch master cylinder, clutch line, clutch and brake pedals + brackets and handbrake - $500 the lot.
Exedy clutch is still available. Includes the flywheel and bolts. $1500
Manual center console including stereo surround, ash tray, power window switch surrounds - $800 the lot.
Gauge cluster, centre gauges and climate control module - $500 for the set.
Autech brace (mounts under the trans tunnel) - $100
Limited slip diff - $500
Cheers
hey do you have the drivers side cargo blind hook (well im assuming its the cargo blind hooK) its the part on the back piller that has a little hook where i think you connect the cargo blind to when extending it.
mine is busted if you need me to send a pick i can.
cheers damo
Hey Damo, is this the one?
$5.00 + post.
Cheers
yeah thats the one, as long as it is from the drivers side. im getting a cargo blind so if that is where it clips to ill be needing it.
no proplem with the cost should still have your details, ill PM you my PO box to send it to once i have paid for it.
i have one more for you, pm to follow.
Autech lower lip in ok condition, one small crack as pictured - $50
RB26 motor, now $4000 (few more pics added)
Exedy clutch is still available, now $1300
Manual gearbox now $850.
Autech rear wing $350
Front and rear brake rotors $150 the lot.
Limited slip diff $400
Cheers
Daniel 0403017900
Edited by RSFour
Would you by any chance have the front left stub axle assembly still? (section that front suspension bolts up to)
The bolt on mine is shagged and can only replace the entire unit.
Cheers
Cheers
pm sent
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
