Parting out r32 gts auto ( 4 door )
i bought the car damaged to take the front and the motor.
just ask me what you need and ill tell you if i have it or not on the forum.
or
contact (leigh): 0403 562 857
rydlemere 2116, Nsw (near parramatta)
https://www.sau.com.au/forums/topic/278459-parting-out-r32-gts-4-auto-4door/
yer mate i bought it off mattew
list of parts because it wont let me reply to most the guys that pmd me
bootlid $100
taillights $75 for both one has a chip on the bottom
rear bar $50
wheels they are only four stud $250
front indicators $100 they are the orange type
power windows switch all 4 $100
speedo surround uncracked $50
heap more stuff available just ask and send an offer$!!!! i hate making prices tell me wat u would pay i can list on ebay for interstate buyers
A pillar trim?
i got drivers side
make an offer.
drivers door trim ??
also drivers seat ?
i believe the drivers side trim has some small peeling. ill try take photos tomorow.
how much for drivers side rear door and fuel lid. will be in sydney this weekend.
Also interested in rear power window switch and drivers door switches.
If u can get back to me asap 0405822066
