Hey there its time for me to depart with my R33 gtr
Im a mechanical technicain by trade
its running the standard airbox with hks2530"s A 3inch exhaust, and 15psi with no boost controller more of a permanet bleed system, so boost cannot be alterd, tuned it with nistune (32gtr ecu) to produce and easy 270rwkw an extremly conservative tune,
The car averages 420 km to tank with this tune, and is very responsive,
This gtr is still running the hicas system as i see no reason to remove it, as its not a race car , the car is extremly smooth and pleasent to drive,
Its still got the origional GTR dash wich only goes to 180 km hour, 142000 km on the clock
Has 18x265 Volk wheels wich stick like glue.
I have recently installed new Bendex pads all round and had the rotors machined,
Really this car must be seen to be appreciate, its clean origional and almost untouchable by the police, (exhaust might be a tiny bit over the 96db )
Come down to my workshop if you are genuinaly interested and ill put it on the hoist and ill let the car do the talking
dyno sheets available aswell
May trade for an auto turbo car of simlar value or cash my way,
dont really care if it sells or not im sick of changing gears though
price is $24000
the car is located in ferntreegully or rowville, VIC
cheers
post-42536-1247137597_thumb.pngpost-42536-1247137733_thumb.pngpost-42536-1247137869_thumb.pngpost-42536-1247138000_thumb.pngpost-42536-1247138032_thumb.png
https://www.sau.com.au/forums/topic/278508-r33-gtr-swap-or-sell/
Saw this car yesterday, and it is absolutely immaculate.
Owner knows exactly what he's doing too and has obviously maintained the car to the very highest degree.
The wheels are honestly some of the best wheels I have ever seen on a car too. These pictures make them look like ordinary silver 5 spoke rims, but there's a very nice inner blue lip decorated little silver plates which the pictures don't show.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
