Guest dieline
Thanks for that guys ...
Meggala I still owe you some pics of my Navara, when it is presentable enough to have a picture taken I will send em to ya. Not happy with the last paint effort so it is getting done again.
BTW I just got a K-27 external gate turbo for it so I should be up in the 220+kwatw soon!
Dieline ... the name .. had it for years when I was skyline obsessed (still am actually) but have always needed a ute so I tried to make the best of both worlds lol, Nissan ute with skyline running gear.
See you on the forum - or street!
Regards,
Dieline
(is it just me, or does starting up at a new forum sorta remind you of changing schools when you were a kid??? lol)
https://www.sau.com.au/forums/topic/279-hello-everybody/#findComment-9829
Sort of ... In the way that you keep in contact with all friends, some even changing skools with you, you start off at the new school wary and try not to make a bad impression, then you start acting like yourself again after a while and everyone learns what a whack you really are ....
Not a personal experience ...
https://www.sau.com.au/forums/topic/279-hello-everybody/#findComment-9830
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
