Greetings all,
My friend is looking for a Defi Boost guage for is Golf GTI. Problem is he is looking for one that shows PSI instead of bar. Is there anywhere in Australia that supplies them, and rough costing for them?
People have been asking rediculous pricing as apparently they are sourcing them from America?
Regards,
Matt
https://www.sau.com.au/forums/topic/279070-defi-guage/
Hi Guys,
Ive got a defi PSI gauge in my car. I was lucky enough to have bought the gauge off a distributor in melbourne who sold his business and was selling off his stock on ebay. He gave me the choice of PSI or Bar.
I think his username was silverstone1956
I can only suggest you contact him via ebay and see if he can advise you where to get hold of one in Australia.
Hope this helps
https://www.sau.com.au/forums/topic/279070-defi-guage/#findComment-4716055
I dont have a clue, i didn't even know that they made them in PSI until my mate was absolutely sure that they did. I am sure nowdays that they would cost quite a bit, so no point in getting one. He just wants it because i dont think he can read bar.
https://www.sau.com.au/forums/topic/279070-defi-guage/#findComment-4717438
yeah they make pretty much the whole range of defi gauges in imperial measurements for the US market. like temp in fahrenheit, pressure in psi etc. tell him to get with the times. we have the metric system and as such don't read pressure in pounds per square inch. lol. kg/mm or bar is the way to go. :mellow:
but if he absolutely must have it then try US ebay.
https://www.sau.com.au/forums/topic/279070-defi-guage/#findComment-4717646
:cool: "convert bar to psi".
Boost gauges are generally pretty inaccurate anyway and you rarely look at it. I would not pay much extra for psi personally.
What makes you say that? Id like to think they were pretty close to accurate if the reason for having it isnt just bling factor?
https://www.sau.com.au/forums/topic/279070-defi-guage/#findComment-4725397
5 different people i know who have different brands of boost gauges (and my own car) have all had readings that have not been the same as when they were dynoed. I would like to think a dyno would be the more accurate of the two and in each case it was anywhere from 1-4psi different to the gauge in the cars.
https://www.sau.com.au/forums/topic/279070-defi-guage/#findComment-4727711
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
