Like the title F/S HKS SUPER POWER FLOW AIR FILTER KIT this is in great condition with a new 200mm replacement filter head unit , all braces and bolts are with it + pics to help with install if you need them.
This kit is for an R34GT-T but the set up will fit others , please don't ask me which I don't have the foggiest it's 90mm ( 3" ) and you can see the bolt patern in the pic.
Heres a link if you want to check out RRP on a newby.
http://www.300zx.com.au/pricelists/pricelist_hks.htm
Here's a pic
doubleclic the pic when it comes up and you'll get a bigger image.
I'm looking for $125.00 + post and pack if you can't pick up or I'll swap for a GFB Stealth or Hybrid BOV with nice cash your way .
Please contact by post or PM .
Edited by BASHO
Price reduced bump
Here's a pic
I'm looking for $90.00 + post and pack if you can't pick up or I'll swap for a GFB Stealth or Hybrid BOV with nice cash your way .
Price reduced bump
Price reduced bump
Here's a pic
Price reduced bump
Is the pod still available?
Let me know cheers
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
