Hey guys, I have recently purchased a R33 GTR, and in my pics, u will see when i have the headlights turned on, only the 2 outter taillights light up?
Is this normal, or has somebody tampered with the bulbs, or is there a fuse or something that is blown making these lights not light up both lights on either side?
i havent had a chance to check if there is actually bulbs in these lights yet, they might have been removed for some reason. anyhow if anybody can let me know if all 4 taillights light up on there gtr, that would be great. i know they used to on my gtst, thats what made me wonder...
Hey guys, thanks for all your replies, well i was right to be suspicious, when we pulled out the bulbs, they were twin filament type which is ok. but what the previous owner has done ( probably japanese) has taken the bulbs out and got some duct tape, cut little squares and taped up the connection on the end of the bulb that makes the taillights work. but he left the brake light one so it would work. wierd huh? anyway taillights all work now.
  • 2 years later...
I know its been ages since this post, but could you please help me how you fixed it? I have the same problem only with one light blown, but it comes on when i press on the brakes... :) Yes, I am a noob at this sorta things...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
