I am looking at having a turbine housing extrude honed and need some recommendations on where .
From a sniff around Specialised Power Porting at St Helen in Victoria looks popular .
Has anyone used them and were you satisfied with the result you got ?
Cheers and thanks , Adrian .
https://www.sau.com.au/forums/topic/280690-extrude-honingpower-porting-where/
I don't think it's such a good idea to get a turbine housing extrude honed. You will disturb the wheel/housing clearance and the turbo will become unresponsive.
I've had inlet and exhaust manifolds and a compressor cover done by SPP. Due to a change in the setup I never used either of these components but I have before and after flow figures for the manifolds. There is no change in clearances with the comp cover - because none of the machined surfaces are touched - only the volute is done.
Also SPP doesn't do twin scroll ex housings.
Edited by juggernaut1
  • 1 year later...
You'd have to call Andrew at SPP for prices as it was a while ago when I got mine done.
As stated in my previous post I never used the extrude honed parts from SPP as I changed my setup and sold the parts off.
Although had my new twin scroll ex housing setup extrude honed in the US (SPP does not do twin scroll housings)....C-Red is just finalising at the moment.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
