G'day guys, I need some help with removing a broken exhaust stud.
Top row - closest to the firewall, I don't have a drill small enough to fit between the block and those 2 air con pipes, so I need someone with a right angle drill, apparently there are people who drive around and do this professionally.
Anybody in Perth able to help me out?
Vehicle is sitting in my driveway in Swan View, not moving.
Here's a pic of the thing.
Stud is snapped off approx. 5+mm inside the block.
-Nic
Edited by Nic_A31
https://www.sau.com.au/forums/topic/280747-help-needed/
Yeah but I couldnt see anyone that could come do it in my driveway. The car is in a thousand pieces and isnt rego'd, so I can't move it unless I somehow re-assemble it with a really bad exhaust leak, and try for a temporary movement permit. Just as hard as pulling the whole engine out and doing it myself, but I'd rather just pay someone $100 to come do it for me in 2 minutes flat.
Stupid Ceffy.
https://www.sau.com.au/forums/topic/280747-help-needed/#findComment-4735968
-Nic
Hey mate
you can buy a angle adaptor at bunnings for $15 or so wich fits into a normal dril, thats how i removed my broken studs. hope that helps
Cheers
https://www.sau.com.au/forums/topic/280747-help-needed/#findComment-4736219
Got the f**ker out with Adam's help (Living Legend that bloke is)
Dispenced about half a small can of WD40, drilled the whole way through the stud, then tried a screw extractor (the round windey type), which didnt work, I had a small set of different type of extractors that are like a square set, you hammer them in and twist. Worked like a charm.
The drill ended up being off centre. The regular extractors were slipping at both ends, so advice for anyone follwoing, or anyone who ends up in this thread in the future (searching, google, whatever) is to use the squarred wedge in type.
https://www.sau.com.au/forums/topic/280747-help-needed/#findComment-4743422
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
