Its that time again,
Whos going? Im thinking about it but at this stage the weather isn't looking too good. If it doesn't get much better by sat morning i might give it a miss...
Mallala forecast:
Sat
Aug 1
Clearing Showers
16°C
Edited by SkyHi_33
https://www.sau.com.au/forums/topic/281262-mallala-grip-prac/
  • Replies 70
Posted Images
My front right shock is gone so I will have to give this one a miss. Not to mention I'm gonna be falling from the sky at 200kph while the race is going :)
Fabs, check out the info from one of the other Mallala prac day threads :no:
E.g http://www.skylinesaustralia.com/forums/Ma...y-t264900.html#
Many variables on oil temp mate - power output, rev range you are using (ie experience on track) sump size, oil pump, turbos (water vs oil cooled) etc. Usually a stockish GTR (with standard initial mods of exhaust, boost, intake, tune up to around 240rwkw) will be up there over 100 degrees after 8 laps or so, ambient temperature dependant. For tomorrow, with a session of a couple of sprints and a cool down in between (which will also help your tyres, and brakes cool down) you'd be pretty good. Main thing is to let it cool once it is hot for a lap or two then you can get back on it. Or you could fit an oil cooler in record time.........
There is absolutly no way I could make this event because of work commitments ffs but I think next session I will come out. Been out a whole heap of times to watch a friend of mine race, he has a white VL Turbo, got 1:22 or something very similar as his fastest lap and will be coming out shortly with more mods so I think I'll definatly come down for the next event and enter.
Goodluck guys and no one twist there cars. I was there last time watching when an evo 8? hit the wall on the straight after the hairpin just as the kink in the straight is. Slightly damp roads + full racing slicks = understeer :rofl: Never heard what happened to the driver, he was taken to hospital not moving tho
New oil and air filter are in, new pod, new plugs, topped up brake and steering fluids, checked brake pads and under body for leaks. Gotta do tyre pressures tomorrow before i head out.
What air pressures should I be running on 18's? 225/40 front 245/45 rear. Was thinking around 30-32 front 32-34 rear?
i see, last time i ran 36/38 and felt like a bit too much... that was on 16s with 205/55 tho.
will go for higher psi and let some off during the day till it feels right i guess, cheers!
time for bed and early morning then :angry:
Edited by SkyHi_33
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
