cut and paste, please call me if u have any questions and want to buy something cause sometimes i dont go on the net for a week 0448812018, and all custom parts fit a ma70 supra
this one has been updated and easier to read
PRICES REDUCED
all parts were working when it came out of the car.
all parts done only 5000ks, parts located on the mornington peninsula, victoria and no prices include postage
who ever speaks to me first has dibs so if ur keen call me on 0448812018,
the whole setup made 220rwkw on 8psi, 264rwkw on 12psi and predicted over 300rwkw on 17psi and i have dyno sheets to prove it
extreme xtra heavy duty clutch 1800lb brass button and chromoly flywheel purchased from race brakes in port melbourne(awesome shop, go have a look if ur near by) $1200 or $900 with ur stock clutch and flywheel and ill pay for postage, this was one of the best mods i ever brought. i will be getting one for my evo
hks evc 4 boost controller $300
intercooler and custom piping hpc coated and also a apexi twin chamber blow off valve paid $350 i paid $2750 i want $1000
we still havent got the bar off to take a photo of the piping hooked up this is just the piping going into the intake
t70 turbo (no shaft play) exaust manifold 40mm wastegate and 3" straight thru dump and z20 air flow meter also comes with pod filter and all rubber fittings to fit upto a stock intercooler. so you bolt it straight up to a stock supra $1200 might seperate
pic of manifold, turbo and wastegate
also if someone wants to buy the cooler piping and turbo setup which i paid $4450 you can as a package for $2000
genuine do luck type 2 front bar and has light mounts and lights make an offer or it goes on the car when i sell it
polished intake manifold $180
in this picture this bit was not polished. when i brought the seller did not tell me this
my boot install pulled 136.7 db at a sound off and have the sheet to prove it, it was running one 12" comp sub, i will install it in your car if you buy it, i will supply 2 sets of 6x9 jbl and 1X 2 channel amp and 1X 4 channel amp and the fuses. if interested pm me for more details $1200 flexible
in this pic the cover plate was not carpetted and i was running a different sub and amp when i did the db
item: Sard Rising Rate Fuel Pressure Regulator Standard and Fuel Pressure Gauge
Brand new in boxes never been used $200 ono including delivery
PM me
link to specs (its the one on the left)
http://www.upgrademotoring.com/performance/sard_reg.htm
https://www.sau.com.au/forums/topic/281561-supra-part-out/
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
