Looking very clean man, good stuff! :)
I went to Repco yesterday for some quotes, the guy said that the car isn't listed on the paper. He suggested I go to Bilstein on the Princes Highway. Took a trip there, the mechanic had a little doze off looking at the car haha and then recomended some things to do with it, then took me to the office to get some quotes.
x4 Bilstein Shocks - $1350
x4 King Springs - $400 (He said he can get Tein Springs in for a little extra, not much though, said it was like within 10%)
x2 Sway Bars - $400
How is that sounding?
EDIR - Oh and they charge $600 for labour.
Edited by Turk1
  • Replies 50
Also I got a sound system in the boot of my car so the back sits lower than the front which is understandable....however the front of my car is WAYY to high for my likings. Could this be because the suspension is to soft? Will the above suspension setup fix this? Or like is there sometihng else I should be doing? Becuase its sorta bugs me eveytime i see it lol...
Edited by Turk1
$2750 sounds about right there. The shocks are expensive because there Bilstein but they are the best shocks. Only thing i would look into is the springs if you find some good ones for 600 its still under $3000 :mrt: .... $2950
the labour is good price if it includes a tune to suit the GTS-4
Ok well I got another person I am going to call tomorow for a quote. Can I ask something though...don't know if I am going to get flamed for this lol but what if I go for just the coils and the sway bars with the stock shocks?
the coils will lower your ride so you will be closer to the ground and therefor better control.
Swaybars are always an awesome mod, there probably better than shocks. Still shock would complete it.
Definately going to get some swaybars, heard alot of good about them. I'll see how I go with money...also, a member on the forums is selling some HKS coilovers...i am interested in them but also double minded becuase everyone says there not the way to go for a daily.
d2 coilovers are 10kg at the front and 8kg at the rear...........not even track skyline have shocks rated that high, the reason i said is because these anodized coil overs are to heavy for Aussie roads. Read up about coil overs on the suspension forums, they will give you the info on whats good for its money and whats not.
I agree it would defiantly work out a lot cheaper but i doubt the handling will be half as good.
you can get them with lighter springs if you want, mine are alot lighter, like 6 and 4 kg...cos yeah we arnt allowed to use the heavy track set up on public roads either, and you can adjust the spring stiffness quite alot within its weight range, ive driven a mates mitsu GTO with tein shocks and its rock hard compared to my set up. personally i think my handling is very good, D2 are also very stiff laterally, i reckon their great value for the money
in that case then if you can change the spring no problem then they would probably save lots of money. Still prefer Bilsteins for the handling but 6kg and 4kg is a massive improvement for there 10kg, 8kg setup.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
