Drivin home last night, snail went pop, emo deep inside me came out.. anyway, Im thinking of rebuilding the 3037s and putting a t3 .82 rear on it (currently running .73 t2) or should i just fork out the bigger bucks and go for a gt35r with a .63 rear? Either way ive got to buy a 6boost and f**k the t2 mani off. So whats your thorts? Its a redtop rb2.2 with tomei poncams.
https://www.sau.com.au/forums/topic/282567-3037s-went-pop-rebuild-or-gt35r/
Hmmm...so many options...what kind of power are you after and how much response do you wanna lose down low? i'd lean towards a gt3076 with a 0.63 exhaust housing...or maybe a 0.82 but that might be quite large for a 2.2L...
Red top is an R31 engine isn't it ?
You can answer you rebuild question by asking yourself if you liked the performance you had before the puff of smoke .
I would be very wary of GT3582Rs on an RB20 based engine , pretty big turbine and compressor for an engine with small cylinders ie 2L based six cylinder .
If you hold high hopes of generating and using 320Kw then a turbo like that may have some value , I can't see it ...
Even GT30 based turbos are pretty healthy sized things on an RB20 (+10%) , people tell me it's the limited valve and port area in them that dictates gas flow and therefore power ceilings .
Anyhow you need to identify which 3037 you have to know what can be done with it . If it's same one as the GT3076R then you can order cartridges for them and fit whichever sized GT30 turbine housing you like in gated or non gated form .
If your 3037 has a ported comp cover try to reuse that , could save you some money .
If you can post the ID tags numbers I can identify which one it is and then its a case of seeing which parts need to be replaced if you want to go that way .
Your call , cheers A .
I dont mind the 3037, but it will still be really hard to break 400 @ the wheels with it, the gt35 on the other hand will produce more power with lower boost which id much rather have. My main concern is how laggy it will be, i dont mind abit of lag aslong as its on before 5.5kish.
Edited by Justa32
A loose water line won't cook it, thats more of an additional safety thing - so long as it had a good oil feed/drain it should have been fine.
Either way, a GT3076R will crack 400hp @ wheels fine... if you are struggling to with a 56-trim full GT3076R then its the engine moreso than the turbo which isn't flowing enough.
400rwhp with a 3076r isnt really the easiest thing to achieve with an rb20... sry but i dont agree with your post.
What you said above is not disagreeing with my post - a GT3076R is FINE for 400rwhp, and as you said above its not the easiest thing to do on an RB20. Thats not because of the RB20 + GT3076R combination, its because of the RB20 part of it. You have to spend the money to make an RB20 making >400whp, or push it that hard. GT3076Rs are making >400whp left right and centre on better motors - you could upgrade to an RB25 when you change your turbo then the 400whp will be easy >_<
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
