Its a pretty broad question
Personally I'd go with the 34, newer, more attractive etc etc.
Make sure you get one with low kays, and have a look around the exhaust to see if there is much oil on the bumper. Better still get the owner to rev it to 2000, then 3000, then 4000 only for a few seconds and see if there is any junk coming out.
Take it for a drive and listen for any unusual sounds or behavior
Theyre both good really I just prefer 34's to 33's
Either one with low Kms and strong service history; not ragged around the edges and no disturbing signs.
Check the VIN to see if the car has come from Hokkaido where they salt the roads & rust is prevalent.
Do compression tests & take a mechanic (and if poss a panelbeater friend) with you for inspections.
Probably prefer a R33 GT-R over a R34 GT-T over the still nice R33 GTsT. Depreciation is better with the GT-R.
Does your licence permit a GT-R? A couple of good R32 GT-Rs at Top Secret and Powerplay atm...
(I'd be careful about leaving a deposit at the latter tho' until they trade their way out of...)
  • 11 months later...
  • 3 weeks later...
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
