Ok,
Rianto wanted me to post this...so that I can share with all those considering the swap....
I bought a set of 2005 350z shocks and springs that did low kms for an inflated price due to the demand for them!
These were fitted last weekend...
Pics of V35 with stock suspension...
Pics of V35 after the 350z suspension was installed...
Thoughts...
1. Was it worth the money?
A. Definitely!!!!
2. How does the 350z suspension compare with the V35's suspension?
A. 350z is a tad more bouncy/bumpy, however, still very very comfortable
3. How much did it lower the sedan?
A. As you can see, it's about 1 inch.
4. Which stock springs and suspension is lighter?
A. The 350z ones are slightly lighter....say, maybe 500 grams lighter overall...It definitely felt a bit lighter when I carried them...
5. How difficult was it to fit the suspension?
A. Well, I didn't want to dirty my hands/fingers, since I now got an office job for 3 mths, so I took it to my family mechanic and he charged me $120 (quite expensive)....It took him about 1 - 2hrs as he also gave my brakes a clean... So, it is not hard to fit....
6. How have the 350z springs changed the handling dynamics of the car?
7. Have you gotten around to getting a full wheel alignment yet? (1" drop can still make a lot of difference toe wise)
congrats you seem very satisfied with them :P
How much did the z suspension worth? + $120? To be honest I didn't see a difference at first look on before and After fitment until having a second close look. At least you reckon it's worth it And comfy.
Wheel alignment? Kidding, right? I spoke to the mechanic about it, he says not to even worry about it...
Handling characteristics? At very slow speeds on bumpy roads, I feel it is a tad bumpy...almost feels like coil overs...so i was quite surprised by that. Turns into corners, etc with no noticeable difference. However, my Mrs says the car doesn't feel as refined now due to the bumpiness. Anyway, I have been driving it to work everyday and it is fine for me...Feels like I am in a sportscar now....hehehe...
if you even remove a shock and replace the SAME one, you should get a wheel alignment. because you have lowered the car your toe has been affected (as already posted) and youre gonna f**k out your new tyres
spend the $60 and get a 4 wheel alignment or spend $800+ on a new set of tyres in about 5000km
wait till u put 20in low profile tyres, the bump nag will increase
oh, man u got nagging trouble waiting around the corner soon lol
I can even tell straight away when going from profile 45 on 18in to profile 35 on 19in that it gets bumpier on stock shocks , let alone from 17 to 20 like what u're planning to do...
^^^^+1 for wheel allignment if you value your tire wear. I've had z suspension in my car forabout a year now and have to admit it was he best bang for buck mod. Will start to explore height adjustable coilovers soon as I want to go a bit lower.
agree with rianto, going from 18s to 19s is still bearable. Think twice before going to 20s. And to achieve the VIP look you are after you would need a much bigger drop than z suspension
:D personally, if he told you that i wouldn't worry about going back to see him
any decent tyre shop can do an alignment for around $40-$70 and 15 mins, it will bring your tyres back into spec
as you may already know even a 1" drop can make your wheels go from this ||-o--o-|| to this //-o--o-\\
maybe not a drastic change but enough to make a difference to your tyre's overall wear and life
couldn't agree more. I had a whiteline kit in my old R33 whichc lowers it by about 1"
although the neg camber increase was subtle and it works a treat on the race track, on the road it worn the inside of my front tyres in less than 10000km
for street use I recommend keeping the front alignment camber degree as stock as possible, if you want more corner handling, get a front caster rod bush/arm and increase your caster, so when your steering wheel is straight the wheels will be ||-o--o-|| and when you're turning right it's //-o--o-//
or \\-o--o-\\ when turning left (this is if viewed from behind). with that setting when turning in addition to body roll/centrifugal shift to one side, your setup on the road will push it towards a more 'neutral' corner ||-o--o--|| during hard cornering and you get more grip.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
