Need some help finding a really long lasting tyre. Will be going to uni next year and will be broke. lol
Looking at 235/45/17 all round or 235/45 front and 255/40 rear. Not decided yet. I was looking at the 595Evo, although I want something with pretty decent wet traction.
Any recommendations would be great.
Price is no concern. Well I'd like to stay under 400 a corner.
Cheers
a mate has 215/45/17s Falken RT215 semi slicks.... he drives his rex a few times a week and on the weekends it can get a bit of a hard time.. they have been on there for 2 years now and hardly worn at all.. at this rate he'll get at least 4 years out of them... and they are super sticky for the street and awesome in the wet. he got them off ebay, brand new for $250 per tyre... best performance bang for buck hes spent yet.
yep re001's for sure.. got them on my barge.. no probs so far..
great in the wet, when im on the freeway my mates hate sitting behind me, due to the amount of spray the tyres kick up.. doesnt bother me too much!!
The RT215s have been discontinued for a while, so any stock left will be quite old. I'm not sure how much that matters to some people.
I will say that I'd agree though. I used to have RT215s and they're the best streetable tyre I've ever driven on. Falken's replacements, the RT615s, aren't much chop in comparison.
I've heard from some people who've driven on RT215s, RT615s and Kumho KU36s in reasonably powered cars who really don't rate the Kumhos. They will be cheap, though, but not my first choice. Also, with a treadwear rating of 140 they won't last long.
Bridgestone RE001s are a good choice. I've also heard good things about Toyo T1Rs.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
