nooo! could of know sooner, just replaced new piping for my pod today and scared that something might happen if the car was on the dyno, but ill be coming tomorrow and cheering
Better on the dyno with a professional mechanic next to it than mid-corner through the hills...
I'm home early, had enuf of the heat and homo wind lol, awesome day and finally could put some faces to usernames, and my power read out was definatly a surprise, all smiles :huh:
Firstly massive kudos and thanks to Cara, Ruby, John Keen, Shane and anyone else involved in putting the day on. Was a great turnout, a good variety of cars, no car died (I hope the R31 wagon was ok), some good dyno numbers and most importantly was a well run event. :P
Congrats to Andrew (Blue32) for taking out the Dyno Queen trophy with 390.x rwkW! :no::huh:
I would have liked to have seen how close to that I could've come but alas the new Blitz EBC didn't want to release more than 11psi. ;)
sorry i had to bale kinda quickly. i lost track of time and was running really late to pick my silvia up from the tyer shop :huh:
good to meet new people and see other people i havent met before.
i was hoping for more from my car but not at the same time considering its stock :P still had standard dump pipes haha
thanks for setting the day up had a good time!
heya
sorry but im out :( took the car to road and track.... problem only got worse and theyve diagnosed two internally leaking injectors... worst timing ever, but at least someone else can get a run - i know the car feels like its trying to run a 100 sprint after being punched in the balls... it tries... it just... cant...
-D
Edit that said, does anyone have a couple of stock 444 nissan gtr injectors? will pay beer
hey mate ive got a bag of stock GTR injectors, some damaged, some may beed the caps replaced (costs like $5 for all of em) but some are also in working condition. and i am partial too beer.
i'll have a look over and find the good ones if you want?
Thanks to all who came and attended. A top effort to all. Good to see many cars with different power outputs having a go.
Some God-awful fueling issues won me the wooden spoon ... but it was good to get in there and have a go even tho I knew it was down on power. At least I got best presented stagea. :P
Congrats to Andrew (Blue32) for his 390rwkw win! Awesome to see those numbers. :(
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
