I today took my r33 with quite a few mods to EFi today at Stayplton, I would just like to thank Rick, Shaun and the boys for all their efforts today to find out where i wasnt making power, They are an exeptional bunch of blokes which is really trying their best to influence the car scene in a good way, all you want to know about anything, if they cant give you an answer straight away they will try their best to find out, i highly recommend them to anyone wanting to diagnose their cars performance, they flow injectors to see wheather they flow to their stated capacity eg:550cc they will check to make sure all injectors flow the same, very pleased with my 1st experience which i will go back in the near future to get a wolf v500 computer fittted for a VERY decent price.
Thanks all.
https://www.sau.com.au/forums/topic/283519-efi-performance/
  • Replies 54
Posted Images
yeah mate, really they spent about 2hours talking to me about my car, exactly where is holding me back, my injectors too big, and just giving me options on where to head next, I do recommend them great guys man.
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4769623
Thanks all.
Couldnt agree with you more man, I droped my 34 of there on friday and will be leaving it there for a week to get a whole bunch of stuff done. Whitey's a bloody champ and he and the guys really enjoy helping and teaching anyone who wants to learn.
I even bought some new wheels and tyres after i droped my car off and whitey told me i could get them delivered to the shop and hed get them all fitted on the car ready for me when I get back from up north.
Ill post some pics when I get my car back :)
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4770676
  • 1 month later...
Yeeeaahhyaaaaa picked up my 34 from EFI yesterday ;)
All I can say is WOW it was worth the wait :P The boys there have done an amazing job, the quality of the finished product is just unreal :blink::D
It sounds awesome, has power everywhere and just looks P.O.R.N IMO :P
A big thanks to all the team at EFI for all the quality time and work they put in to my car :)
Will post up some pics later today.
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4865769
Yeah its getting there one thing at a time, Anna is ringing today to find out how its going, Whitey was sending an email with the list of stuff to be done but apparently none of them are massive issues so thats good.
your gar is looking good whats that turbo? 35R with a .63 rear?
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4866048
Oh good stuff.
Turbo is GT35 wit .86 rear
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4866064
looks like they did a good job.
however im not keen on that front bar/no side skirts/ricey rear bar look that youve gone for there
any dyno sheets or anything? could imagine it might be a touch laggy?
Yeah the came like that but im looking into gettin some skirts now :banana:
Yeah got a sheet just have to take a pic of it and wack it on pc (bein lazy)
Its not really that laggy, makes full boost just before 4k and when it comes on its UnReAl :dry:
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4868003
So far i've had a great experience with them, plenty of communication (lack of communication is my main beef with workshops), and they've been patient with my shitc**t of a car so far :-)
And they like cupcakes.
https://www.sau.com.au/forums/topic/283519-efi-performance/#findComment-4868130
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
