Hey guys, Just needed some opinions on which speaker you guys would think is best value for money out of the few listed below and why you think so:
I listen to mainly RnB/Rap/House/Energy/Trance. If that helps.
I plan to only run fronts and no rears.
Will be bridging a 4 channel amp to run the fronts.
1) Soundstream PCC6N 6 1/2" Component Speakers $RRP 399
2) JL AUDIO Evolution C5-650 C5 Component Speakers $RRP 699
3) Pioneer TS-D1720C 6.5' 260W Component/Splits Speaker $RRP 549
4) NEW ALPINE TYPE-R SPR-17S 6.5" 330 Watt 2-Way Splits $RRP 399
5) Boston Acoustics SL60 6.5" Component Speakers $RRP 549
Thanks guys :)
Edited by Black R34 GT-T
https://www.sau.com.au/forums/topic/283617-need-decision-on-front-speakers/
okay champ spr-17S are 349 RRP.
http://www.alpine.com.au/products/product.asp?modelID=314
and i havent heard the boston or soundstream splits in a car, but for what its worth audition a set of Focal 165VR $519 RRP. fantastic speaker for 500.
bro has a set and they are very good , i find tweeters to be soft and not to tinny sounding like some of splits i heard.
at end of day you should listen to all of them and see what ones best for your ears :D
Mate you cant go wrong with JL Audio. The c5 is one of the best speakers i have heard in a while.Made in Germany and they come very close to the JL ZR.Come see me at JB HI FI Warrawong and i will hook you up.Ask for Aaron.
Yep cant go wrong with jl audio speakers, dont get put off with low power output, These are pure quality :D
Focal are not bad also. Wouldnt go pass these 2 unless goin extremly high end alpine cos other than that they are poop imo.
Run 6" or 6 1/2 inch in back also could be a thought. Then get a Jl audio sub also. W3 an up :P
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
