im plannin on gettin some after markets seats for my car preferably leather or vinly i was thinkin of the leather autotecnica seats that retial for $500 for one, which is a fair price considerin there leather but i heard they arent very comfortable so now im thinkin mayb OBX??
please post your thoughts on weather or not either of these two companys make a decent seat
and NO i cant afford Momo recaro etc..
and yes i want vinly/leather
and post only what you no :shake:
heheh
thanks
Originally posted by mexr
SlikSilvia, got any pictures of the OBX or Autotechnica($500 ones) seats as im also looking around for some aftermarket seats. Cheers
hey man yeah i do have a look at there site
i wouldnt mind buyin yours stock seats off you once you get your aftermarket seats! even if the cloths in crap condition cause im gonna get them re-trimed :))
let me no if u want to sell em
here
http://www.autotecnica.com.au/products_fs.html
Originally posted by RadiuM
FYI.
My brother in law has a pair of OBX CARERRA's Reclinable (yellow) for sale for $700 for the pair. They have NEVER been used and are still in the box.
Shaun
hey man i wouldnt mind checkin them any pic's as i was lookin for yellow or red as long as they wernt TOO bright yellow :D
what suburb is he in?
retial price?
He's in canningvale.
Here's some info on them, they are the same seat at the Corbeau
Corbeau Website
they look like this, im not 100% on the black bits though as its been so long since I last saw them.
I think he's only willing to part with them for 700 the pair as i think thats what he got them for. im not 100% on that but ill get him to logon to this forum and reply here.
Shaun
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
