Hi Guys,
We have been selling these for while now and can get them real quick, so if you need good handling tyres like the KU36. Please give us a call..
Designed for SCCA racing that demands high Uniform Tire Quality Grades, this incredible tire delivers unrivaled dry grip with split-second steering response, and its unique footprint is designed to deliver consistent handling performance at high G-forces.
Special Features
* Low void asymmetric tread pattern with circumferential grooving for high cornering grip.
* Ultra fine carbon black compounding for maximum traction.
* Ultra wide tread contact with highly rounded shoulders for optimized footprint shape during high lateral loads.
* Developed for quick autocross warm-up while maintaining race track durability.
* With a W speed rating, the tire delivers an optimum run temperature of 203 degrees Fahrenheit.
* UTQG rating of 180 AA/A.
Comparable Competitor Products
Falken Azenis RT-615, Yokohama ADVAN Neova AD07
205/50/15 KU36 $155.00
215/45/16 KU36 $135.00
225/50/16 KU36 $155.00
215/45/17 KU36 $165.00
225/45/17 KU36 $195.00
235/45/17 KU36 $170.00
245/40/17 KU36 $215.00
245/45/17 KU36 $205.00
255/40/17 KU36 $230.00
275/40/17 KU36 $250.00
285/40/17 KU36 $260.00
295/35/17 KU36 $235.00
315/35/17 KU36 $250.00
335/35/17 KU36 $255.00
225/40/18 KU36 $235.00
225/45/18 KU36 $235.00
235/40/18 KU36 $210.00
245/35/18 KU36 $210.00
245/40/18 KU36 $255.00
265/35/18 KU36 $240.00
275/35/18 KU36 $275.00
285/35/19 KU36 $270.00
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/
  • Replies 121
im interested in these tyres.
are they still good for road use and still handle ok in the wet because i do most of my driving on the street.
also how much for 4 of them my tyre size is 235/45/r17.
thanks.
scott.
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/#findComment-4778879
thanks.
scott.
They are extremely grippy in the dry and not bad in the wet either can do Fitted $700
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/#findComment-4778927
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
