Plays iPod/DVD/CD/SD/USB Plus More. **No Reserve**
This item is like new, only selling due to sold my car and this wasn't part of the sale. Item was purchased brand new from jb-hi on the 22/03/2009. Also has extended 1 year warranty therefore you get 2 years warranty all up, which must be organized through jb-hifi not me.
Buyer will receive;
1 x KD-AV7100 unit
1 x Remote Control
1 x iPod connector cable
All wiring
All Original Packaging & Manuals
Also Original copy of the purchase receipt from JB-HIFI.
Enjoy video and music from your iPod as well as various other sources via USB, SD slot, and Front AUX, with 5.1-channel surround sound. Multilingual display is available in English, French, Spanish, Chinese, Korean, and Russian on the in-dash 7-inch wide touch panel monitor.
RRP $1,199.00
- MOS-FET 50W x 4
- Built-in 7-Inch Wide Monitor
- Front USB Port (MP3/WMA)
- SD Slot (JPEG/MPEG1,2/MP3/WMA)
- MP3/WMA Compatible (DVD/CD/USB)
- DivX®/JPEG/MPEG1,2 Compatible (DVD/CD/USB*)
- iPod Video Playback**
- iPod Audio Playback
- 5.1-Channel Dolby Digital/MPEG Audio
- Bass/Treble
- 4V Line/Subwoofer Output Level
- Gold-Plated Output Terminals (Front/Rear/Subwoofer/Centre Channel/Second Audio)
- Gold-Plated Composite Video Output Terminal
- Gold-Plated Input Terminals (AV/Video)
- TFT ON/OFF
- Touch Panel
- Multilingual Display (English/Spanish/French/Chinese/Korean/Russian)
- Rear View Camera Ready
* DivX® files must be less than 2Mbps forplayback on USB.
** Control only available from iPod
For more info http://www.jvc-australia.com/JVC/client/c_...&prodID=370
Selling for $700.
Located in thomastown, melbourne.
Hi mate, does it have bluetooth? Or need buy JVC bluetooth kit for this function?
Sorry champ no bluetooth.
Price droped to $650.
So much interested but still for sale. :( Buyer wont be disappointed.
il take it for 650 if you send it to gold coast???
would prefer to pick it up off a fellow sau member..
http://cgi.ebay.com.au/JVC-DVD-Receiver-wi...id=p3286.c0.m14
Cheers
Darren.
Edited by HKS_R34
Please advise if this has been sold. I'm currently in Melbourne and can pick-up tomorrow.
Sorry champ, item is on hold until tomorrow as i have a buyer. If transaction fails. I'll let you know.
Cheers.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
