Hey guys,
im returning my car back to stock and have some bits to sell.
HDI Front Mount Kit: all pipes, joiners, clamps, brackets.. bit dirty, few scratches, but overall micky mouse working order, core in good cond, no bent fins or dents. $200
Hicas Lock Bar: Steel Jobby, does the job, almost new. $50
Alloy Cradle Rings: all 8, have slits for easy install.. all in good condition. $20
Just Jap Silicon Radiator Hoses: top and bottom silicon radiator hose, pretty blue. almost brand new condition. $50
Cusco Rear Coilovers: you can have all 4 but LHF one is bent at the top... just needs a new shaft. they were bought from an importer and were second hand when i got them, but they have no leaks, squeaks or damage.. work well. rears are 6kg and fronts are 8kg.. 5 click damper adjustment. $200 for rears only, $300 for all 4.
Alternator: came off vehicle with 60000kms, good cond, bought as a spare, never used it. $40
Manual Boost Controller: not sure what brand, its small and blue... works fine. $20
all parts are located in East Maitland NSW, im happy to post anywhere in aus though.
cheers
Linton
https://www.sau.com.au/forums/topic/284381-r32-gts-t-randomdrift-parts-sale/
coilovers awaiting payment but to answer your question, yes they are fully height adjustable... sorry, i just thought that was a given.
hicas bar no probs, its still in the car so ill get it out tomoz, will pm you when ready.. you can pick it up anytime from then.
Coilovers, Boost Controller, Hicas Bar, Lock Rings.... all gone!!
found some more bits though.
HKS Old School BOV.. its the old style super sequential... makes a mad noise... sounds like a whip crack or something.. makes a very "two stage" noise. bit dodge but in good nick, comes with pipe. $50
found some other stuff.
RB20/25DET Genuine Nissan VRS kit... missing head gasket only.... all other gaskets still in packaging... exhaust, intake, valve stems, cam cover gaskets... all there. $50
cheers
Linton
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
